I’ve noticed some strange behavior with my two interior temp sensors shortly after booting up or rebooting. Each registers a very high temperature only to settle down to the “actual” temp after a minute or two. The attached screen grab shows a reboot during the middle of a water test and the aforementioned temp spike, though only on the Beer Temp Probe.
Not sure if its relevant but these two internal sensors share common wiring to the brewpi and are “split” inside the fridge and each split is wired to the RJ12 connectors respectively.
The result of this is that the Pi wants to go into cooling mode when it picks up these misread beer temps, when in fact the actual temp is spot on.
I just finished beta release 0.4.3b. Will post instructions tomorrow on how to update. Do you have this problem consistently? Would be good to know if this release solves it.
Should we update to 0.4.3b2? Or is it not ready yet? I just ran the update script, but it looks like the firmware for photon is still 0.4.2 and a newer version is not yet available. I guess I rather wait until everything is ready
